Labview installation problems: ni-skyline-rabbitmq-support (19.6.0.49152-0+f0)
Trying to install LabVIEW 2020 community edition through the NI package manager but the above error keeps coming up.
I have tried the solution at https://forums.ni.com/t5/NI-Package-Manager-NIPM/LabVIEW-installation-problems-ni-rabbitmq-3-7-3-491... . But it did not work.
I'm running a 64bit Windows 10 machine. Let me know if you need any more info.
Any help would be greatly appreciated. Thanks in advance
(1,941 Views)
I try to install LabVIEW 2020 community edition through the NI package manager but the above error keeps coming up.
I'm using 64-bit Win10.
Thanks in advance.
Errorlog:
===== 2022-Sep-04 16:20:00.999128 =====
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125083
Request type: 30
-125083: ===== 2022-Sep-04 16:22:27.761335 =====
Request type: 30
-125083: ===== 2022-Sep-04 16:22:57.754357 =====
Exception in PreInstall::LaunchPackageManager. Error code: -126309
Launched NI Package Manager, but it returned an error
-126309: ===== 2022-Sep-04 16:31:24.927946 =====
Request type: 30
-125083: ===== 2022-Sep-04 16:38:33.270445 =====
Request type: 30
-125083: ===== 2022-Sep-04 16:43:08.529942 =====
-126309: ===== 2022-Sep-04 16:53:57.296679 =====
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125084
Request type: 30
-125084: ===== 2022-Sep-04 16:54:10.367851 =====
Request type: 30
-125084:
(1,934 Views)
Hi  LeonXD,
If you check your attached link's solution and the problem is still existing, I suggest you to to uninstall and reinstall the drivers. It might be helpful in this case.
Regards
(1,835 Views)
