Labview integration with NI XNET
We have license available for NI Hil system version 2018, We are facing an issue while the LABVIEW modeling when interfacing the inputs with the X-NET for the CAN Communication between the Vehicle spy and X-NET. We have tried this with two different versions 1) NI-XNET 20.5.1 2) NI-XNET 18 but the error is same. Please find the attached image of error below.image (1).pngimage (1).png
(1,784 Views)
What are the name of the Interface wired to the XNET Create and the name of your XNET port in NI MAX?
https://tmesystems.net/
(1,732 Views)
We are using NI PXI-8513 and Ni-XNET interface CAN1.please find the attachment.NI XNET.pngNI XNET.png
(1,695 Views)
Your XNET device is installed on an RT target. Did you run your VI under the RT Target or host PC?
(1,686 Views)
yes, we followed the same process though facing same issue.
(1,677 Views)
we run the VI on host PC
(1,663 Views)
