Labview interface for HTML web server
I need to interface an embedded microprocessor running as a web server via HTML to Labview. Specifically the LabView application needs to send the microprocessor commands and receive it's responses via HTML. Has anyone done this before - any ideas?
(3,219 Views)
Just an idea - you might check out the TCP functions on the Communications subpalette. They should allow you to communicate to and from the standard HTTP port on your web server. Disclaimer: this is how I would start it. I have not done anything like it before.
2 cents
(3,219 Views)
bnheather,
You may want to look at the LabVIEW Internet Toolset. This toolset includes HTML VIs for reading and sending HTML documents.
Randy Hoskin
(3,219 Views)
