Labview is not responding to Abort execution button
Hi
I have a complex project that sometimes freezes.
'Abort execution' does not work when freezing occurs.
PC resource usage:
CPU: 12%
Memory: 66%
I use WIN10 x64.
It takes a lot of time to Lv to close, it shows for  a long time as 'Resetting VI: xxx.'
Any ideas why 'Abort execution' not working?
(1,536 Views)
Could be many possible reasons. For example, if you're inside of the DLL call, which takes long time. When you hit "Abort" button, then LabVIEW unable to interrupt external code and will wait until execution is completed.
(1,499 Views)
