Labview keeps freezing up...
I am running a VI that is in constant exectution with many loops and sequences. Non of the loops or sequences are running in parallel. Anyway, at one particular part, it keeps freezing up. Then when I try to stop the execution, nothing happens. I have to use task manager to close labview and then it displays a message saying "Resetting the Vi." Eventually I have to hard reboot the PC. Anyway, I have attached a VI with the area of concern.
Anyone know the problem?
(3,413 Views)
Hi MrB.,
When I downloaded and tried to open your VI, it cannot find all the other subVIs that are required for your VI to run
Anthony Wong
University of Toronto
Chemistry Department
(3,403 Views)
Here are 3 out of the 6 you will need.
For the other 3, look below.
(3,384 Views)
Here are the other 3.
(3,383 Views)
