Labview looking for subVIs in wrong directory
I have been having problems with Labview for a while. Whenever I try to use some of National instrument's own subVIs I always get a message similar to that shown in the attached picture. I know the subVIs are there because I can navigate to their location in my installation directory and load them using the browse function. But there are hundreds of them, maybe more. I can't do that for all of them and really, labview should do this automatically. I do not understand why this is happening as I only started with Labview recently and would appreciate any ideas on how I might resolve this issue. Thanks.
(3,236 Views)
Accepted by topic author shankov
I sounds like you've managed to move a folder, causing the previous paths to be corrupted. Even so, once you've pointed out a folder it should find most others automatically and you can save all VI's with the updated path.
You can also make sure LV's Path setting under Options -> Paths -> VI Search Path, is similar to the attached picture.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,230 Views)
that problem (most often) boils down to: you must have linked to those functions in a wrong way or you must have moved some of the calling functions to a different place! Both possibilities are bad…
Do you use projects? If you do you should look into the unresolved conflicts section…
(3,227 Views)
