Labview modbus based code to CVI ?
Hi all,
  I need to convert a Labview code (wich communicatio with external instrument using ethernet), to a CVI one
  this code is using VISA to opne TCP interface, and MODBUS protocols vis,
  could this be easy to implement?
SASA
(3,082 Views)
You might want to post your question in the CVI board.  People in the forums there would be in a better position to tell you how difficult it would be to use Modbus in CVI.  Perhaps they have some Modbus libraries already.
(3,061 Views)
