Labview on Linux
Hi All,
I am working with labview 4 the past 1.5 yrs.But all my experience in windows platform.
I would like to learn about Labview on Linux.
Where do i get useful info for working with Labview under linux platform?
I want to know all the info including making exe under linux platform.
Thanks in advance
Message 1 of 12
(5,967 Views)
Hi
The best place to look would just be on
I would reaserch into running such an old version of LabVIEW however as Ni cannot support LabVIEW 4 on linux platforms.
As for making an exe, in later versions of LabVIEW the process is Identical and built via the project but again on LabVIEW 4 I can not be sure as I do not have a copy of it here to test.
best regards
Graham Green
Software Product Marketing
NI | Emerson
Message 2 of 12
(5,956 Views)
Hi Graham,
Thanks for the timely help.
Can u help me little more as i am doing a research work in labview on linux.
Is there special versions for linux seperately in labview.
Is there more tutorials regarding labview on linux platform.
Thanks again
Message 3 of 12
(5,935 Views)
Hi there
Yes there is a sepparate version of LabVIEW for Linux
Quite a usefull resourse to look at is linked below. This might answer some of your questions.
There is not I'm afraid an evaluation version for linux available to download but if you are familiar with using LabVIEW the the functionality is similar in both applications.
I hope this is of some help, I'm sorry that I cannot be more specific but without knowing your application needs then it is hard for me to reccomend the next steop in using labview and linux in your situation.
best regards
Graham Green
NI | Emerson
Message 4 of 12
(5,926 Views)
you will find the download link and how to install instruction (in german only) to a free full LabVIEW 6.1 english distribution for Linux here:
http://www.labviewtutorial.eu/de/index.php?option=com_content&view=article&id=10&Itemid=17
Message 5 of 12
(5,923 Views)
Thanks 4 the reply.
But its in german.
Is there any english version?
Message 6 of 12
(5,898 Views)
Only the installation instruction is in German, the LabVIEW distribution itself is English one.
Message 7 of 12
(5,893 Views)
Thanks for the links.
As i told i was working with labview in windows environment.
I want to make a research work on working of labview in linux environment
That is starting from the beginning...which versions are for linux and is there any deifference in control panel/block diagram of linux compared to windows.
I want to know how to make exe after developing an application.
So is there any link that provide from the beginning.All labview tutorials are aimed for windows environment.
Is there anything for linux?
Thanks again
Message 8 of 12
(5,881 Views)
Hi user_1,
The best resource for Linux is https://www.ni.com/en/shop/linux.html as mentioned above.
Hope that helps!
Jennifer R.
Message 9 of 12
(5,822 Views)
Thanks again
The first version of LabVIEW for Linux was at around LabVIEW 5.1. There is a big difference between LabVIEW 4 and LabVIEW 5 and an even bigger one between LabVIEW 5 and LabVIEW 8. You will not be very happy to constantly switch between different LabVIEW versions.
The 6.1 version that you can download from the German server is a LabVIEW full development system. It does not include the application builder so you can not create executables.
Most likely you are going to need to buy a LabVIEW license if you want to build executables too and that will probably mean going with LabVIEW 8.5 since NI does only sell the current versions.
Rolf Kalbermatter
Message Edited by rolfk on 06-13-2008 11:29 AM
Rolf Kalbermatter  My Blog
Message 10 of 12
(5,810 Views)
