Labview on Raspberry pi 3b+
Hi, guys. Is there any way to run Labview VI's directly on raspberry pi3b+? For example I want to run some grapics on raspberry (not on my pc). Ive installed Linx and can control GPIO on raspberry, but i want to see some visual elevents on raspberry.
(2,761 Views)
AFAIK, LabVIEW on RPi\Linx won't get you VI Front Panel graphics. So, the short answer is no.
You can of course improvise...
A web page could communicate with your program over TCP\IP for instance.
You can interface with a GTK application.
You could even talk TCP\IP to the X11 server on the RPi, to manually create windows and controls, if you have enough time.
(2,721 Views)
