Labview program hangs even after showing correct result
       I created a labview program that calls a function from a C# .dll file, and that function calls another labview program, written for simple summation. But when i run that original labview program, even though the called C# function fetches correct result (i.e. sum) from the other labview program and shows on front panel, the labview program hangs and gets closed.
      What should I do in this situation. I am looking forward to your help. Thanks in advance.
(3,173 Views)
Some, like, code would be helpful. Otherwise it's hard to provide feedback such a generic question.
(3,131 Views)
