Labview programming to convert weight measurement into mass flow
I have continuous analog input measurement from weight scale. I want to convert the weight measurement to mass flow measurement.
E.g.:
1st minute weight measurement: 200kg
2nd minute weight measurement: 300 kg
3rd minute weight measurement: 350 kg
and so on.
I want to convert those weight into mass flow which is
1st mass flow:(300-200)keg/1min = 100kg/min
2nd mass flow: (350-300)kg/1 min = 50 kg/min
and so on.
So the weight and should be updated every minute, whatever the time value of while loop iteration.
Can somebody give solution of this case with labview programming? (structure in block diagram)
Eko
(3,982 Views)
Hi Eko,
is this some kind of homework?
Well I suggest to use two shift registers to hold mass and time, then two subtract nodes to get the difference of current and old vlaue for both and finally a simple divide to get the mass flow...
Look here to get the basics!
(3,971 Views)
Hi Eko,
I know this is a bit of a long shot... But is there any chance that you still have the VI file for this. I am currently doing a similar project to this, and it'd be great if I could compare my VI with yours, as not all aspects of mine are working right now.
Jon
(3,583 Views)
Hi Jon,
why don't you attach your VI here so we take a look at it to provide suggestions?
(3,581 Views)
