Labview quits on launch - Mac OS X
Hello. I just installed the Labview 8.6 student version and restarted my computer (Mac OS X 10.5.8). I try to launch the application but it basically quits on launch. It shows up for a second in the dock and then disappears. I really need a way to fix this asap. Thanks.
(3,925 Views)
Try whether this will help [broken link removed 1/9/26; article no longer available]
(3,914 Views)
Hello Nine,
Are you seeing behavior as described in the link muks posted (thanks muks!)? Have you tried rebooting? Unfortunately if you are in a time crunch reinstalling is really the best thing to do, have you tried reinstalling?
With warm regards,
David D.
(3,899 Views)
Well, I tried reinstalling and rebooting, and it still does the same thing. I forgot to mention, it doesn't 'crash' in the typical mac sense. There's no error log, I don't even get that crash window with the cancel/report/relaunch options. When I double click, the icon shows up in the doc for barely a second and then disappears again.
(3,887 Views)
You noted that you are using Mac OS X 10.5.8 which is a supported OS, however what processor type do you have? Only Macs with Intel processors are supported for LabVIEW 8.6, note this KnowledgeBase:
https://www.ni.com/en/support/documentation/compatibility/18/labview-and-macos-compatibility.html
Did you follow the installation procedure as noted in the release notes here:
https://www.ni.com/pdf/manuals/371778d.pdf
Message Edited by Dr. Doiron on 10-29-2009 10:48 AM
With warm regards,
David D.
(3,864 Views)
Yep, my mac's an intel. Specs: 1.83 ghz intel core duo, 1.5gb ram. I install everything the way the release notes say, except I haven't even got a virus detection program to disable (insert mac joke).
Also, my installation process doesn't give me a choice between easy or custom install. And nowhere does it ask for a serial (I got the CD with the labview book and there's a serial on the CD sleeve).
(3,842 Views)
The only textbook I am seeing comes with LabVIEW Student Edition 8.2.1, found here:
http://zone.ni.com/devzone/cda/tut/p/id/6644
In this case this is a known issue, see this KnowledgeBase:
http://digital.ni.com/public.nsf/allkb/BEE49BB55F1C660F8625748F0057D2B3?OpenDocument
Either way with no errors and reinstalling not working I would recommend following the steps in that KnowledgeBase and requesting a new CD, it sounds like there is an issue with that CD.
With warm regards,
David D.
(3,805 Views)
