Labview - reading an array from a com object
Hi!
I have constructed a com-object in visual c++. This object will just
return an array of variants. The method connected to the interface has
one out parameter that consists of a pointer to a variant. I dont know
how labview handles this type. It seems that it doesnt recognize the
type. It just gives the error message, "A null reference pointer was
passed through the stub"?!?! I have also written a com-client in c++
that communicates with this com-server. This one works fine! How does
labview handles arrays?! I have also tried to just return one "Variant
value" from the server. Same problem here, "A null....".#"¤%"%
com-server implementation:
STDMETHODIMP CTEEServices::TestVariant7(VARIANT inData, VARIANT
*pOutData)
VariantInit(pOutData);
LPVOID pvdata;
int *pElement;
pOutData->vt=VT_ARRAY;//Set VARIANT type to array
SAFEARRAYBOUND rgsabound[1];
rgsabound[0].lLbound=0;
rgsabound[0].cElements=10;//10 elements
pOutData->parray=SafeArrayCreate(VT_I4,1,rgsabound); //Create a
safearray in VARIANT
pvdata=pOutData->parray->pvData; //Get address to array
pElement=(int*)pvdata;
for(int i=0;i<10;i++) //Fill it up!
*pElement=i;
pElement+=1;
return S_OK;
regards,
Peter
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,246 Views)
Hi
I'll send you an example of how I retreve a 2D array from an ActiveX control
in C++ an how it is wired in LV
Hans
wrote in message news:892sjt$c0i$1@nnrp1.deja.com...
> Hi!
iant
> *pOutData)
> LPVOID pvdata;
> int *pElement;
> pOutData->parray=SafeArrayCreate(VT_I4,1,rgsabound); file://Create a
> pvdata=pOutData->parray->pvData; file://Get address to array
> for(int i=0;i<10;i++) file://Fill it up!
> *pElement=i;
> pElement+=1;
> return S_OK;
> regards,
> Peter
> Before you buy.
[Attachment C2 test.vi, see below]
[Attachment ActiveX.txt, see below]
(3,246 Views)
