Labview robotic module: Inverse Kinematics
i upload a 5-axes arm from solidworks to labview. actually i can command this arm and i can get correctly the different coordinates of my end effector (i verify this using the forward kinematics vi). but the problem is when i try to calculate the inverse kinematics, an error which is handled ''Error -310040 occurred at NI_Kinematics.lvlib:Inverse Kinematics (Point).vi : LabVIEW Robotics:  (Hex 0xFFFB44E8) LabVIEW cannot converge to a solution in the number of steps you specified. Make sure that the serial arm can achieve the transform you desire.'' so i try to get a position calculated by the forward kinematics vi, so am sure that my arm can achieve this position, but the same error is also handled.
so i upload for u my vi to understand more my problem
thanks
Message 1 of 13
(6,764 Views)
yes i did..i think that my problem come from an error in DH parameters..so i upload my vi in order to verify them with me
thanks
Message 3 of 13
(6,673 Views)
I downloaded the .zip folder you posted, but it says that it's empty. Could you try to repost that?
Message 4 of 13
(6,661 Views)
i upload it again but i think that u ll get the same problem
i can pass to u my email(if u want) it will be easier to send u my files
Message 5 of 13
(6,658 Views)
i use labview robotic module to command a 5-axes robotic arm. so upload the design of my arm from solidworks to labview using the extension vrml (.wrl). but i didn't find a method to complete axes of the different links..how should i so organize these axes ( as shown in pictures below. it's only a simple try but it's not correct the organization of these axes that i've made). i didn't understand which method i can use in order to get after that correct results when i will use denavit hartenberg convention
thanks in advance
Message 6 of 13
(6,667 Views)
You're probably going to want to check your math. Can you give it more steps? Which coordinates are giving you problems?
Message 7 of 13
(6,645 Views)
 i made the design of my arm using Solidworks and i upload this arm to the robotic environment simulator of labview using the extension VRML .wrl (as shown in the picture which are saved in the folder "links axis" below : my first problem is there: which method i use to make the axe of each link), then i made the different joints (here i used the convention of hartenberg to make the different axis).then i passed to my code where i tried to verify the forward kinematics, first i put an indicator to observe hartenberg parameters:i notice that they are OK except the coordinate offset joint i don't know wh‌y they aren't null..then i verify the position of my end effector: it's OK,,but from these positions i couldn't realize the inverse kinematics(the error is show below).i think that the problem come from the oganization of different axis of each link
u can consult my vi/project in the folder below
Message 8 of 13
(6,643 Views)
Can you provide some more information regarding what you've tried previously, if any? What do you mean by organizing the axes?
Marco C.
Applications Engineering
Message 9 of 13
(6,628 Views)
u can see the folder below,,u ll understand my problem
thanks
Message 10 of 13
(6,625 Views)
