Labview runtime 2010 with windows embedded compact version 7.0
we would like to run Labview runtime 2010 on a touchdisplay with windows embedded compact version 7.0.
The hardware that comes with the display uses an ARM-Cortex - A8 i.MX53 processor. This processor does not support the runtime versions that can be downloaded from the National Instruments homepage.
Are there any ways to run Labview runtime 2010 with that kind of processor?
Thanks heaps for your support!
(3,084 Views)
if the run-time cannot be installed on your processor (if the processor does not filfill the system requirements), then you have no chance to get the run-time working.
=> you have to use an other processor.
If it is not working you have no change getting it working.
Best Regards, Fabian
(3,037 Views)
