Labview runtime engine plugin problem in Mac OS X
Fab,
I overlooked the intial version information in the post. Currently 10.6.2 (Snow Leopard) is not a supported Mac operating system. I have linked the Knowledgebase article discussing LabVIEW support for Mac here. I would highly recommend visiting the Product Suggestion Center to provide feedback directly to the R&D team, on providing compatibility for 10.6.
Please post back any additional questions you may have. I very much appreciate the time spent troubleshooting this behavior. I will be forwarding this information also as a Corrective Action Request, for future work in the Snow Leopard version compatibility.
Thank You,
Patrick Corcoran
Application Engineering Specialist | Control
Message 21 of 41
(3,264 Views)
Patrick,
Do you have the CAR for this issue?
I want to know if Snow Leopard is going to be supported at some point.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 22 of 41
(3,120 Views)
Hello Fab,
As of the release of LabVIEW 2010, Snow Leopard is a supported operating system for LabVIEW and Select Drivers*. The 2010 release notes will detail the Operating System support.
Cheers!
Patrick Corcoran
Message 23 of 41
(3,107 Views)
Patrick,
We finally got around to upgrading LabVIEW to 2010. I installed the LabVIEW 2010 runtime engine on the Mac OS 10.6 (snow leopard).
However, when I try to connect to my remote panel it says that the plugin needed is not installed. I checked in the help menu on Safari and lists the LabVIEW 2010 runtime as installed.
I tried connecting from Internet explorer and once I put the port on the IP adress (http://168.192.1.10:8000/RemotePanel.html) it connected with no problem. So I know the html page has the correct information and I know the remote panels work. It just does not work on Mac OS 10.6 (Snow Leopard).
What else can I do to enable remote panel connection on the Mac OS 10.6 (Snow Leopard)?
Fab
Message 24 of 41
(3,031 Views)
Patrick,
This is the message I am getting:
Screen shot 2010-10-01 at 12.44.24 PM.png   Screen shot 2010-10-01 at 12.42.33 PM.png
Message 25 of 41
(3,025 Views)
Would it be possible to post a larger image?
Also, is port 8000 on the MAC configured for both HTTP and TCP/IP communication? Is there a firewall enabled on the system? Has the LabVIEW 2010 RTE been added as an exception?
Patrick Corcoran
Message 26 of 41
(3,012 Views)
Why would the port need to be configured in the MAC? I thought that would be configured only on the cRIO system, correct? The MAC is only being used to see the remote panel. The code is running directly in the cRIO system that has the 192.168.1.100 IP address.
There is no firewall in this system, so no need to add the Run Time Engine as an exception.
Here are the larger images:
Message 27 of 41
(3,004 Views)
The two first images show the message we get no matter if the :8000 is added to the address or not.
The third image shows that LabVIEW runtime Engine is listed as an installed "plugin".
Message 28 of 41
(2,997 Views)
Fab,
Would it be possible to test with Firefox on your system? Also, to confirm, the full LabVIEW 2010 RTE has been installed on the system? Also, please verify that your version of the RTE matches the version of LabVIEW code running on the remote target. This document outlines the version compatibility information.
Thank You,
Patrick Corcoran
Message 29 of 41
(2,982 Views)
From just a cursory glace at the screenshots, it looks like the LabVIEW RT installation on the cRIO is serving a page that requires a plugin that can interpret 'application/x-labviewrpvi100' but Safari only has a plugin called 'application/x-labviewrpvi2010'.
I would open the plist and edit it to match the plugin name that the cRIO is serving.
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
Message 30 of 41
(2,961 Views)
