Labview runtime engine
Hi
We have some software we use to diagnose machinery - i've tried to install it on my computer but its missing the Labview Run-Tine Engine
I click yes to download it which takes me to a package installer, and then i get another error coming up saying it cannot be found?
can someone point me into the right direction for where to find this engine? will i need to purchase it?
screenshots attached
thank you
(3,359 Views)
You can download the runtime engine here. It is completely free.
You need to select version 2020 and also make sure it is the correct bitness (32bit vs 64bit).
Did the program come with an installer? Does it need any drivers? Thy could have included all requirements, including the correct runtime engine with the installer to make life easier for everybody. What does the software do? Does it use any additional modules, such as vision? What kind of measurement hardware does it use?
(Who wrote the software? Are they still in business? If they just gave you an executable, that would not be very professional)
(3,348 Views)
Wow thank you for the reply i was looking everywhere for this, ill let you know how i get on with it
Same scenario, old software guy leaves the company no one knows anything about how to get it installed etc so im just trying to get it to work
We plug a cable in our heat pumps and it reads the data from the unit, compressor hz, sub cool ,heating etc
(3,296 Views)
Do you have external instruments? For the communication i'd wager you need NI Serial (if it's RS232 or RS485)
Qestit Systems
Certified-LabVIEW-Developer
(3,287 Views)
