Labview runtime libraries
I would like to install a labview program with another installer program, instead of using the Application Builder. I need to know what are the runtime files and registry settings that I have to distribute with my application.
(3,450 Views)
For Labview 5.1.1 you only need the lvrte.dll in the directory of your
application or in the system directory, i.e. c:\windows\system\
(3,450 Views)
Thanks for the answer. But we are using Labview 6.1,on win2000 OS and the Application builder installs a whole group of files in the c:\program files\National Instrument directory, with Shared and Datasocket subdirectories where you can find the lvrt.dll in c:\program files\National Instrument\Shared\LabVIEW Run-Time\6.0 directory. Also, The application builder doesn't seem to be installing any lvrte.dll file.
(NOTE: I'm using the installation of the labview runtime with the application builder in order to see what are the files and registries that are modified/added and then try to replicate that without the application builder, but it seems a bit complicated, there's a whole hierarchy of files installed and many registries modified/added)
(3,450 Views)
Sorry, I also ment the lvrt.dll. But doesn't your application work only with
the lvrt.dll in the application or system directory (and the data socket
files, if your application needs datasocket)?
(3,450 Views)
I found the webpage that supports Niko's knowlegable answer. I attached it below if anyone is interested.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/5184addcf46654078625675500703871?OpenDocument
Jeremy
(3,450 Views)
Is that really true for LabVIEW 6 ? ... That's when the models & script
subdirectories appeared... and you definitely need the other dll's and the
serpdrv, too... and recently I found that you need the nicont dll's if you
want to use Active X containers...
Bill
Jeremy Braden wrote in message
news:506500000005000000E49A0000-1027480788000@exchange.ni.com...
> Jeremy
(3,450 Views)
