Labview: save for previous version (8.5 to 6.0)
Hello All!
I have problem with saving for previous version 8.5 to 6.0.
As I know, usually it is possible to make a step back to previous version only.
It means for convertion from 8.5 to 6.0 I should make the following chain :
8.5 to 8.0
8.0 to 7.1
7.1 to 7.0
7.0 to 6.1
6.1 to 6.0
 Smiley Mad
Could anyone suggest some better way please?Smiley Wink
Message 1 of 9
(3,529 Views)
Hi Rustan,
the way you posted is correct, the other solution is to write your code again in LV6.0. Smiley Wink
Mike
Message 2 of 9
(3,513 Views)
My method is correct theoretically, but in practice I need to have all of these versions installed on my PC. Smiley Surprised
It makes practical application of this method little bit difficult.
I thought maybe somewhere there is some tool for such conversion.....
Thanks for reply!Smiley Wink
Message Edited by Rustam on 06-26-2008 02:55 AM
Message 3 of 9
(3,509 Views)
Hi Rustan,
if you have only some vi´s, you can post them and the forum community will help you. Smiley Happy
Mike
Message 4 of 9
(3,498 Views)
No, thanks, I have a few old PCs with 6.0 so it tends to be a regular work.Smiley Mad
Strange that nobody asked this question before.
Message 5 of 9
(3,473 Views)
Hi Rustan,
another solution is to ask NI. I know there is a tool to convert older VI`s to newer versions (you have to order it AFAIK it´s free of charge), maybe there is a tool for the other way.
Hope it helps.
Mike
Message 6 of 9
(3,443 Views)
I also heard some rumors about such tool, but never seen it in a real life.
Well, I have already requested NI, so I expect they will answer me soon.
Rustam
Message 7 of 9
(3,406 Views)
The tool to convert very old VI (3.x or older), is nothing more than LabVIEW 4. Saving for previous versions is a question that has been asked numerous times and the official answer is always the process you are doing now. While all things are possible, I doubt you will find anything better.
Message 8 of 9
(3,395 Views)
Well, I also have a lot of doubts.
Otherwise there would be no stimulus to upgrade to new version.Smiley Mad
Message 9 of 9
(3,391 Views)
