Labview simple user interface for Teststand
I am customizing the Teststand simple UI using Labview. I would like to replace the sequence files combo box command and the open sequence file button by a string ring (that contains the sequences names and their paths as value). I also want to run the sequence that is selected (using an value change event on the string ring).
I have not been able to do it, the UI always runs the sequences selected by the sequence file combo box. Can you please help me with this issue?
Thank you!
(2,147 Views)
hello friend I would like to help you but I can't imagine very well what you are trying to do in labview, I use labview 2012, could you link a VI and images of a example of your project even if it has errors but having the idea of ​​what you are trying to do?
(2,098 Views)
