Labview software incompatible for windows xp
Hi.... i have experience of installing labview 2010 and when i try to open the Agilent ESG series example, it works on windows 7 professional. however when i transfer to another pc which is windows xp version 2002 service pack 3, it couldnt load the file as it will hang there forever. I Even try to install a 2009 version, it couldnt work as well. The same problem happen when i try to test to make a simple diagram whereby i wish to connect my instrument via VISA. Please advice is it windows xp facing imcompatible issue and which version of Labview suits for windows xp version 2002 service pack 3. Thanks a lot.
(2,766 Views)
The LabVIEW versions you mentioned work fine and stable on XP.
Richard
(2,728 Views)
Are all the drivers installed on the XP machine?
(2,710 Views)
