Labview statechart compatibility with FPGA VI
I have an issue into my statechart. I have severals states with normal Vi activation which is working fine. But i have a few steps with FPGA VI to launch.
The generation code button (top right corner) is always broken when FPGA VI are included to one state.
The consequence is that i can't launch my application.
All Vi's should work fine because whithout using statechart (launching VI one by one) the system works fine.
Are there known issues about statechart and FPGA compatibility ? Or any help on that problem ?
Don't hesitate to ask questions if something is not enough clear.
BR,
Vincent
(3,093 Views)
Hello Vinvent,
When you click on that button, what kind of message do you get ?
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(3,076 Views)
Hi Mathieu,
You can find attached a screenpicture of my diagramm. You can see the arrow is broken.
The second file shows the different VI i am using. The PWM FPGA is a VI i have to deploy to make my application running.
But the essai PWM RT.vi and Helico 3DOF_cRio_v4.vi are using the FPGA target to run. That's the reason why my arrow is broken.
On the diagramm ;
"Lancement du VI FPGA" state launch the PWM FPGA.vi
"Essai PWM" state launch the essai PWM RT.vi
"Hélicoptère" state launch the Helico 3DOF_cRio_v4.vi
I have an error on these 3 states.
Do you know why ? And a way to fix it ?
I can give you the code if needed.
BR,
Vincent
(3,064 Views)
up...
(3,041 Views)
Anybody can help me ? I need to know if we can run FPGA VI in a state. According to my application it seems it is not. Someone agree with this ?
BR,
Vincent
(3,026 Views)
