Labview to Scilab Gateway
Hi everyone,
I am currently using the Labview to Scilab Gateway and really enjoying it. However, my scilab script is quite big, and requires 5-10 seconds by itself to execute.
To facilitate the user, I intended to use a progression bar. However, I think it is not possible to dynamically get values out of the Scilab Script node. (I was simply thinking of putting a time variable in my script (suppose integer t) and increment it after every 5 lines or so. I could then display it in progress bar.
Is there any way to do this. I could also use set cursor to busy, but that would not be as helpful. Kindly give any suggestions if possible.
(3,860 Views)
(SubVI) with Horizontal progress bar
set scale range
loop until a timeout
update loop with progress along progress bar (numeric value)
simple
Lots of nice extras can be added and tweaks to make it nicer as you wish.
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,825 Views)
Hi James,
As I mentioned earlier, I am facing problems with updating the loop with the numeric values for the progress bar. The scilab script node returns value only when it has completed executing, like a sub VI.
I cannot obtain values from it dynamically. However, I would like to give the user a measure of how much time it would take to complete the script. (It generally takes 5-10 secs but may sometimes it takes 30 secs also for large input data.
It does not immediately seem possible to me. Is there a way??
(3,799 Views)
Accepted by topic author AkkiTriple5
I think you misunderstood me.
If you know the estimated time remaining - from previous empirical experience, then you can create the above described subVI and launch it as a Dialog in parallel to the SciLab function.
A reference to a stop Boolean will allow closing of this immediately on completion of the Scilab function.
This is a technique I often use when I have to launch a process over which I have no control but which I have a good idea how long it might take to complete, just so that the operator knows that the system has not hung. (a classic example would be when programming a chipset via a remote module.)
(3,794 Views)
