Labview to .exe
I have a Labview file that transmits and receives using CAN and also sends and receives using the RS-232 port. I need to convert the .vi file to an .exe file so it can be run on a computer that does not have Labview. I heard it can be done, but how?
(4,254 Views)
The application builder is inlcuded with the Professional version of LabVIEW or can be ordered separately. If, under the Tools menu, you have a "Build application or shared library(DLL)" choice, you have the Pro version and it's already installed.
(4,252 Views)
Hi Dennis,
I have Application Builder and am able ot build an .exe on most of my programs,, however, when I try to build an application from a labview file containing MatLAB script nodes the .exe is not executable.  Instead, when I attempt to open the .exe, the window does not open and LabVIEW freezes.  My employment terminates July 20th and I would like to build an .exe so that future employees don't have difficulties with my program.
I would really appreciate a response.
Thank you!  Enjoy your day!
Ivanka Slywynska
(4,236 Views)
Hi Ivanka,
I'll be as fast as possible...
You are most likely experiencing the issue solved in the following KnowledgeBase:
Why Does My Executable Hang When It Is Opened When I Use A MATLAB Script Node?
Please follow the steps in the KB and let me know if it solves your issue, thanks.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(4,205 Views)
AWESOME!
I've been looking for a solution for a long time now, and it was only a click away!  Thank-you so much!  Just in time!
Ivanka
(4,183 Views)
