Labview version, OS version from within a VI?
How can you determine the version of Labview running and the OS version
running (on a Windows box) from within a VI? Do you need to invoke the WIN32
API? or is there a VI component that provides this?
Any help appreciated,
Marty Burns
(3,005 Views)
You can find at least part of this information from the VI server. Look
at the Application class properties.
Greg McKaskle
(3,005 Views)
> version running (on a Windows box) from within a VI? Do you need to
> invoke the WIN32 API? or is there a VI component that provides this?
> Marty Burns
The VI you want is the PropertyNode vi.
Bring up your diagram and right click to get the vi palette.
Go to the 'Applicaion Control' sub-palette.
Drag a 'Property Node' vi onto your diagram.
The properties you need are:
OperatingSystem|Name "Windows Me"
OperatingSystem|Version Number and "4.90"
Application|Version Number "6.1"
Hope this helps
regards
Remove "spamkill." when replying to this message
(3,005 Views)
Works Great! Thank you very much!:)
Marty
"Dave Langstaff" wrote in message
news:1042727744.276154@dyfi...
> > Marty Burns
> Appli
> Hope this helps
> regards
(3,005 Views)
