Labview washing machine simulator
Hey guys, I'm new to labview. i have been working on this for only a few months and currently im making a washing machine simulator. It is a really simple one, you should turn on the machine, put in mode and start the machine. i have it all done but my programme does not run. there are no errors in it that prevents it from running. I think im using the state machine wrong.
Can you guys please help?
(2,406 Views)
Avoid loops inside loops. You can combine them into a loop with a state machine. The same rule applies to the first start loop.
I would recommend you spend some time going through Exercises and Samples Exams for CLD preparation.
https://tmesystems.net/
(2,361 Views)
Ok I will go through it and get back to you. Thanks
(2,349 Views)
Accepted by topic author ovya
Hi Ovya,
Your code is from newer version of LabVIEW so I cannot see it but I am attaching a solution to a washing machine problem that some guy asked for in a different post (Quick version).
Hope this gives you some ideas.
X
(2,313 Views)
Hi, yes this gave me an idea of how state machines should be. Thank you so much, i have fiixed my errors.
(2,297 Views)
