Labview webcam Problem
Could anyone help me, please?
I've download LabVIEW webcam library from Peter Parente'Homepage
http://www.cs.unc.edu/~parente/labview/webcam1.4.zip
I use my webcam to capture indicator display screen but the charactor that i get is reverse (like look in the mirror)
Could anyone suggest me how to solve this problem? Is there any VI to flip the image and can use with Peter's Libray? I use LabVIEW 6i,sir
Thank you very much
(5,848 Views)
one hardware solution:
turn your webcam and use a mirror ?
SCNR
Greetings from Germany
Henrik
LV since v3.1
(5,800 Views)
What about using function IMAQ Rotate?
(5,792 Views)
Hi Prart
1.- If you have IMAQ vision 7.1, download USB IMAQ driver fron this web and will have no such problems.
2.- If not, convert your image to a 2D array an see attached picture about how to revert image.If it does not run for you, try transpose 2d arrrays.
Hope it helps
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(5,775 Views)
Your webcam driver might have a setting to mirror or reverse the image.
Mine did. I don't remember where you find this but try looking at the driver
settings for the webcam in the Device Manager (My Computer -> right click ->
Properties -> Hardware -> Device Manager)
"Prart" <x@no.email> wrote in message news:191954@exchange.ni.com...
> Could anyone help me, please?<br><br>I've download LabVIEW webcam library
> from Peter
> Parente'Homepage<br><br>http://www.cs.unc.edu/~parente/labview/webcam1.4.zip<br><br>I
> get is reverse (like look in the mirror)<br><br>Could anyone suggest me
> with Peter's Libray? I use LabVIEW 6i,sir<br><br>Thank you very much
> display_capture.JPG:
> http://forums.ni.com/attachments/ni/170/110888/1/display_capture.JPG
(5,767 Views)
Ok, I figured this out. The driver settings I used are in Yahoo! Messenger.
I plugged & played my camera so I don't have driver settings under control
panel nor in another program. But, I can control the image size and
mirroring using the webcam properties in Messenger, stop the Messenger
webcam, start up the LabVIEW vi, and the settings stick.
"DD" <dd@bogus.net> wrote in message news:4231e4ec@PYROS.natinst.com...
> driver settings for the webcam in the Device Manager (My Computer -> right
> click -> Properties -> Hardware -> Device Manager)
(5,722 Views)
Try the attached library. Also see if you can find IVision. They have some free evaluation dowloads for webcams.
(5,684 Views)
