Labview webservice with sbrio
I am trying to make a proof of concept to show how a labview webservice is created on an sbrio. as you can see from the screenshots, I keep getting the error message when I try to run the VI to see if it is working. When I move the VI to a different location like under My Computer, it runs but not under the webservice and thus under the sbrio.  the VI actually deploys to the sbrio. any ideas??
(2,875 Views)
Try simulating the FPGA target and see if it can run without errors. You can do this by right clicking the target > Execution Mode > Simulated. This will give you garbage data, but if the VI can run then your code is fine and there is likely something going wrong with the hardware.
Danielle
(2,800 Views)
