Labview with Aardvark I2C usage guide
Hi all,
I am new to LabVIEW and interested in using Aardvark USB-I2C tool to talk to an I2C device.
1.  Are there any resources [example documentation, sample code, videos ..] you know of that I can refer to?
2.  If not, could you provide me a broad overview of the steps I need to implement to successfully read/write to an I2C devce from LabVIEW?
MYT
(7,776 Views)
Also, just to add a note, I have downloaded LabVIEW vi examples from Totalphase.
Looking on how to proceed.
1. How do you connect all to create a continous loop that reads a few registers and updates a display?
(7,752 Views)
Hi MYT,
Could you be a bit more specific on what you need assistance with?  Did you resolve the first issue you posted about?  In regards to your second post, if you go to Help > Find Example you will see lots of example on how to display data in the manner you're describing.
Bobby Breyer
(7,727 Views)
How can we write data from LabVIEW to aardvark. I am facing problem while writing the data to set values in an experiment related to audio amplifier.
(7,418 Views)
Hey MaheshPanigrahi,
I haven't seen much with Aardvark but these examples may point you in the right direction.
These two links should be essentially the same:
http://www.totalphase.com/blog/2014/06/how-transfer-i2c-data-using-an-aardvark-i2c-spi-host-adapter-...
http://www.totalphase.com/support/articles/202443023-Sending-I2C-Messages-Between-Two-Aardvark-adapt...
Eric
(7,368 Views)
