Labview with Arduino
Hi, i want to control my Arduino with Andriod by bluetooth connection. I am able to communicate between my mobile(android) and Labview, but when i try to send the signal to arduino in that program, arduino gets halt. May be my program is not correct (attached). Please guide.
(3,995 Views)
Upload in 2011 format..Apart from this send your android + labview app also..Want to take a look at it.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,991 Views)
This program is combination of Labview + Android & Labview + Arduino !!
(3,974 Views)
Eventhough I have blutooth palette then also lots of VI is missing during opening of uploaded VI. Can you put all the dependent VIs in one folder and upload it?
--Ranjeet
(3,970 Views)
If successfully communicated with labview arduino, do it via Bluetooth is similar, one would have to get a USB Bluetooth and pair with the device then performing serial communication, add other useful links, greetings
NI LabVIEW Interface for Arduino Toolkit -
http://sine.ni.com/nips/cds/view/p/nid/209835
Getting Started With the LabVIEW Interface for Arduino
http://vishots.com/getting-started-with-the-labview-interface-for-arduino/
(3,851 Views)
