Labview with Labjack T7
Attempting to write to a Labjack T7
I've got reads working I need some help moving boolean values into an array of doubles
I'd like the switches and indicator array to write to the 3rd element of the Values In Array
Newer to Labview and could certainly use the help
(3,160 Views)
You'll likely want to use the "Replace Array Subset" or the "Insert Into Array" function blocks to accomplish your task.  If you are new to LabVIEW there are a plethora of online video tutorials that cover basic through advanced topics: Booleans and Binary Numbers, CLAD 077 Replacing Array Elements (simplest example I could find)Finding Duplicates and randomizing a list (Shows replacing array elements in action).
(3,139 Views)
