Labview with a 8051 board
I want to build a burgler alarm using a 8051 based board with standard IO. I
want to use labview as programming and userinterface. Where can i find a
design or to drivers. Or who else did design such a application????? Or
where to find an application note???
Harrie
(3,323 Views)
I did it using serial communication between 8051's UART and the computer serial port. It is fairly straightforward to implement a simple ASCII command set.
You won't find a driver as such, since your application and command set will be unique. In LabVIEW you send the ASCII commmand to the serial port and read the expected answer.
LabVIEW, C'est LabVIEW
(3,323 Views)
