Labview with keithley2110
I have keithley2110 multimeter. I can measured temprature and vlotage of a battery but when i built an exe file from vi and run it on other computer, the measured voltage is shown as an integer value although temprature is ok.  Why?
Message 1 of 10
(5,663 Views)
Message 2 of 10
(5,640 Views)
Without seeing your code all I can summarise is you are doing it wrong.
=== Engineer Ambiguously ===
Message 3 of 10
(5,625 Views)
Her is my code. In this code ı controll two instruments(Keithley 2110 and 2400). It works on my computer that has Labview with no problems. When i built exe, just measured voltage from 2110 is shown integer values.  The others are ok.
Thanks..
Message 4 of 10
(5,587 Views)
check the regional settings of that other computer...
Message 5 of 10
(5,576 Views)
Which regional settings. Can you elaborate?
Message 6 of 10
(5,571 Views)
Hi limelight,
check the numeric separators. Keithley default drivers expect a point as separator, whereas in several countries the comma is used!
Message 7 of 10
(5,563 Views)
Forgot: Windows - system settings - regional settings...
Message 8 of 10
(5,557 Views)
If it proceed from regional setting , why the temprature that is measured from 2110 has no problem?
Message 9 of 10
(5,547 Views)
Maybe that function is coded slightly better?
I don't have the Keithley driver available here, so I cannot check this.
But the most reasonable idea (IMHO), when a program only reads "integers", when it read "floats" on a different computer, is to check the regional settings on both computers!
Message 10 of 10
(5,526 Views)
