Labview
Hi
i have a question regarding real and complex signal(x+iy) i have written a mathscript file  which are also the commands that works on Matlab. when i run these commands in Matlab they give me values which are complex(e.g 1.00+0.001i) but when i run these commands in mathscript i find that there are no (" i ") imajinary values. Ok i understand  we cannot plot  complex signal but at least i should show some values in "indicators" or the "Write file" i am writing but u can only see real values. There are only "r" but no "theta's".also only "x" but no "y"
how would i generate a complex signal in Labview.
looking for response
Madd
(3,386 Views)
Right click on the output terminal of your mathscript node [Y], select Choose Datatype->1D-Array->CDB 1D
Here's a screenshot to create a Z-plot:
Ton
Message Edited by TonP on 01-31-2008 08:15 AM
My LabVIEW Ideas
(3,383 Views)
Heloo
Tnx for ur help my problem is solved
(3,324 Views)
In the future, could you please provide a better title for your posts? Many people who participate in these forums look at the titles to determine whether it's an area they can help in. All of your started threads simply say "LabVIEW" as the title.
(3,302 Views)
