Lag between text scrollbars
Hi, I would like two text indicators to scroll using one vertical scrollbar (and keep the lines lined up), but there's a lag between them which results in them not lining up.
Is there a way around this?
Many thanks
Graham
(4,118 Views)
Try something like this.
Good luck
-Matt
(4,108 Views)
Thanks Matt, but I can't open that with the LV 2011 I'm using.
I#ve just realised though .. I could have used a listbox!
(4,105 Views)
Accepted by topic author grahamwebb
Glad you solved it.  Here is another solution. 2011 for you.
-Matt
(4,099 Views)
Haha! Nice. It's late, I'm tired.
Many thanks
Graham
(4,094 Views)
