Lagrange Interpolation limited to 13 (X,Y) Values ??
I experienced a limitation using Lagrange interpolation,
I can only use a vector of max 13 values for correct interpolation,
this problem does not appear with nearest, linear, spline, or hermite cubic methods.
Best R.
Nicolas
(3,219 Views)
Have you experienced the same problem ?
(3,203 Views)
I tested the LV example:
labview\examples\analysis\intpxmpl.llb
In fact, there is the same problem with dataset 3 where there is greater than 13 control keys.
The curve has a strange behaviour with a huge peak that downscale all the others near a zero looking value.
This may be the mathematical law which is limited ?
Nicolas
(3,195 Views)
Accepted by topic author nferry
Ok I think I find the solutionon wikipedia Lagrange:
"Lagrange and other interpolation at equally spaced points, as in the example above, yield a polynomial oscillating above and below the true function. This behaviour tends to grow with the number of points, leading to a divergence known as Runge's phenomenon; the problem may be eliminated by choosing interpolation points at Chebyshev nodes."
Hope it helps you.
Nicolas
(3,189 Views)
