Langauge Converter
Hi Friends,
I am not sure whether i can post this question here or not but i am eager to see the response from the NI Support.
Requirement is:
  1. I've an excel sheet where one particular column contains different English sentences
  2. Say for ex: Available options are phonebook call delete phone select ring tone and bluetoothe on (all this kind of bluetooth related sentences)
  3. Some lines may be only words (call, phonebook, deletephone)
  4. Using labview i should read that particular column and convert the respective sentence/word to French and Spanish.
  5. Reading from the excel sheet and writitng back to excel sheet i am thru..
  6. But the Language converter i'm totally unaware.
So, please if anybody worked on such a kind of converter (even a third party software exe include in labview)
please let me know which would be a gr8 help
Cheers,
Suneel.V
(2,909 Views)
Hi Suneel,
to translate your text, you can buy a tool with an interface (ActiveX or a dll) or you can use online services like google.
Hope it helps.
Mike
(2,888 Views)
Hi Mike,
I tried in Google but i failed to locate one.
Could you please let me know if you've come across like this anyhting in the past.
Thanks in Advance.
Cheers,
Suneel.V
(2,883 Views)
Try using the VI Charly posted here.
___________________
Try to take over the world!
(2,855 Views)
