Laser Beam Quality Measurement (M^2 Measurement) using Image Processing (NI Vision)
Is any body previously work on M^2 Measurement of Laser Beam?
If yes, then Please help me out need Little guidance.
I am trying to make a VI which determine Laser beam quality and measurement using NI Vision.
I have a average command on Vision. But, this i am not sure How should I processed?
Any help will be appreciate.
(4,270 Views)
In order to provide any suggestions, can you elaborate a little more on what you are trying to measure? What constitutes as a good quality beam? Is this light intensity? Shape of beam? Size of beam? Etc?
Once you determine what makes a good beam we can then determine what processes you can take to measure those conditions.
(4,208 Views)
Basically, the Laser Beam Determination based on,
Light Intensity
Shape of the Beam
Background Correction
Centroid position X Y
Defining the cordinate system to Beam
Recording the beam location and calculate the change in the location
Size of Beam
Beam Quality in %
Parth
(4,206 Views)
Are you using Vision Assistant by chance? There is a good tutorial on all the different functions that can be utilized with NI's vision software linked below.
Even if you're not using Vision Assistant (which I would recommend doing) you can also create this same functionality with IMAQ VI's in a LabVIEW project as well.
NI Vision Assistant Tutorial
http://www.ni.com/pdf/manuals/372228m.pdf
(4,186 Views)
ok. I used Vision previously for other kind of diagnosis.
Do you have any idea about how can i find the intensity profile of the laser beam using IMAQ?
Parth
(4,183 Views)
I've never personally done it, so I can't really say. But this form post talks about a few approaches to get the intensity profile. I hope that's helpful!
https://forums.ni.com/t5/Machine-Vision/To-Extract-Intensity-Profile-from-Image/td-p/138356
(4,180 Views)
