Last Peak Value
Hello Everybody,
I have a signal which rises and then stabilizes and then falls down as seen in the attachment.
I need to find out the index of the element after which  the signal starts dropping.
Thanks in advance,
cooldude
(2,600 Views)
HI
You can do this using express VI "statistics"
Open the properties and select the options Maximum, Index of Maximum and Last Value
Hope this helps
Regards
Santosh
(2,583 Views)
I have written some algorithm from the requirement what i have understoo.
if you have some doubt, ask me
Shrek
(2,569 Views)
