Last line in excel using MS-report toolkit?
I'm using the MS report toolkit and am trying to find the last cell in an excel report to import data into Labview so I can both manipulate data and create plots from the retrieved information. How is this done?
I would also like to search for the last row/column to add more data to an exsisting sheet instead of inserting it to the top of the sheet.
(3,045 Views)
Hello!
Sorry for the delay, but here you have an example program that do what you asked for! Not using Report Generation Toolkit, just pure ActiveX calls. I attached a Excel workbook so you can test the functionality.
Cheers,
Jimmie A.
National Instruments Sweden AB
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,045 Views)
But do close the "workbook" and "range" references, or you'll get memory
leaks.
"jimmie-a" wrote in message
news:506500000005000000AE710100-1079395200000@exchange.ni.com...
> Hello!
> Cheers,
> Jimmie A.
(3,045 Views)
