Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
Latch an "In Range and Coerce" Output until Reset
Re: Latch an "In Range and Coerce" Output until Reset
steve_bjservice
s
Member
Author
03-14-2007
01:45 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Yes, and it works fine - as long as it stands alone. Once I try to put it inside of another While-Loop, the outer loop stops running.
If it won't work that way, then it probably won't work as a sub-VI either.
Any ideas?
-Steve
0
Kudos
Message
11
of 11
(334 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
