Launch error with "lvinit.cpp"
I've worked with Labview 8.0.1.
When I launched Labview, I've got the following error : "Fatal internal error: lvinit.cpp, line 1427".
Any help?
Best regards
(3,330 Views)
Hello Fred91,
Errors related to lvinit.cpp are due to administrator rights / user rights matters.
Please check that you installed LabVIEW on admin privileges and that users are allowed to read/write on the file used by LabVIEW.
Best Regards,
BRAUD Jean-Philippe
Field Sales Engineer - Nord et Centre France
LabVIEW Certified Developper
(3,326 Views)
actually I've a similar problem after I decide to upgrade the kernel.
I tried to get rid of the message by reinstalling LabView but the error is still there.
Fatal Internal Error : "lvinit.cpp", line 1553
LabVIEW version 8.2.1
this happens with bot root and normal user
Which are the files to check for the right permissions?
thanks in advance,
G.
(3,264 Views)
You're using linux right ? Which distribution are you using ? This error doesn't appear in our database, this may mean that your distribution isn't supported, in this case we won't be able to help you much... just try to update the kernel to the latest version (if it's not already done) and if it doesn't work try a mass compile (be carreful it might last 6 hours).
Best regards
Richard Keromen
(3,218 Views)
