Launching DataSocket programmatically in LabView 6.0.2
Is it possible to programmatically launch DataSocket in
LabView 6.0.2 WITHOUT using any DataSocket functions from previous versions of labView??
(3,676 Views)
Drop numeric or whatever n the front panel
right click
Data operations >>> DataSocket Connections
navigate to what you want to subscrirbe too.
when the Vi is run, the datasocket will be initialized and the indicator updated.
OK, I may have left some of the details out but that should get you started.
Is this what you wanted?
Ben
(3,676 Views)
Thanks for trying. I know how to attach front panel objects to DataSocket for publishing/subcribing to data. This still requires me to launch DataSocket manually from the windows start menu before running the
VI. Otherwise the DataSocket server will never start. In labview 5.1.1 I can launch or close the DataSocket server programmatically. It seems in versions of LabView beyond 6 this functionality has been lost.
(3,676 Views)
OK, that is not what you wanted.
Ben
(3,676 Views)
Click this link to go to a Knowledge Base which discusses how to do this. There's actually a VI to launch it, but it's not on the Functions palette.
J.R. Allen
(3,676 Views)
Thanks.....I did not know that example vi existed.
(3,676 Views)
