Launching Teststand and a sequence
What is the most simple way to launch an instance of TestStand from labview and make it to start executing a sequence defined with path constant in labview?
I saw the TS examples but even the pretty simple one has the callback VIs, and quite amount references which I dont get at the moment so I'm looking for the actual implementation. Maybe later on I get more of an expert of how to properly control TS from LV, but for now I need a very simple launcher.
Thanks.
(527 Views)
You could use the System Exec VI to Run a Sequence File the Command Line, which is probably the simplest way of doing it because you don't need any special VIs from TestStand at all.
(503 Views)
Kudos to you for giving a 100% valid answer to my question.
I probably need to refine my question: I need the second simplest way to start TS from LV. System exec work but I'd like to make this work with the TS API, so later on - if we need it - I can use the API.
(477 Views)
Look at Working with the TestStand Simple User Interface - LabVIEW (TestStand 2013 and Previous) - NI
Jim
(456 Views)
