Launching n number of combo boxes based on n selected at run time
Hi All,
I am looking for something interactive with the system.
This is my problem, I choose a number "n", say for example 5. When I choose 5 I need to have 5 combo boxes open/launched with already provided items on it. And n is a variable, so chances are there to be changed every single time I run my program. Is this possible with LabVIEW programming?
Or I can also try with some other option. It should basically work like a drag and drop of some 6 parameters, so I thought it would be better to have a combo box and proceed. If anyone thinks there is a better solution than this way, kindly suggest!
Thanks in advance!
(3,277 Views)
Hi Medico,
the general answer is: when you want to have a variable number of the same element you should use an array of that element!
Do those comboboxes always display the same set of choices?
(3,271 Views)
Yes, they have the same set of choices.
But may you please be a little elaborate, am not able to get your point!! A novice here....
(3,257 Views)
Hi Medico,
put the combobox in a array and show as many elements as you need…
When you don't know how to work with arrays I recommend to take the free online courses for LabVIEW beginners!
(3,248 Views)
Yes, thanks for your recommendation...I wud look at it!
(3,228 Views)
