Laview MQTT VS HTTP
Hi,, is there any example of testing sensor data speed, sent via MQTT and HTTP ?
Message 1 of 18
(3,078 Views)
HTTP is made for humans, MQTT is made for "things".  Which one do you think will be faster?
Bill
CLD
(Mid-Level minion.)
Message 2 of 18
(3,070 Views)
Yes i know that. It is just for starting point, because i'm new to LV.
Then i wish to test MQTT vs MQTT-SN, or MQTT / SN vs Coap for example
Message 3 of 18
(3,067 Views)
Sorry, I didn't know at what level you needed the information, so I started out very general.
It's "just" a protocol.  (I say "just" because some protocols can be quite complicated.)  It's a pretty tall order for a beginner.  I'm not sure just how much of a beginner you are, so the first thing I would suggest is to look at the training links on the forum page and take the free training.  Then download the protocol pdf and see if you can implement a message.  It doesn't have to be working communications yet.  Just see if you can plug in some stuff in one end and see if the resulting message that you made looks the same as an example message that should be included in the protocol.  Sorry, I can't think of anything else right now.
Bill
CLD
(Mid-Level minion.)
Message 4 of 18
(3,049 Views)
Where to find this examples?
I was thinking to
test time to transfer certain amount of data via the protocols.
Is it a good idea, and how to accomplish it ?
Message 5 of 18
(2,991 Views)
I was thinking to
I'll be darned.. .there are LabVIEW toolkits available for this!!!  I probably wouldn't worry about benchmarking, except maybe to the point of doing a very informal testing on transferring a typical file and watching the clock on the wall.  If you can't really tell the difference there, it doesn't really matter.
Bill
CLD
(Mid-Level minion.)
Message 6 of 18
(2,983 Views)
I was hoping for more tutorial-like help, but ok I'll try that
Message 7 of 18
(2,964 Views)
Sorry about that, Martin.  The best I can advise is to take advantage of the training links on the forum page, then see if you can make at least one of the libraries listed there work.  😞
Bill
CLD
(Mid-Level minion.)
Message 8 of 18
(2,944 Views)
I have problem with JKI account, so i can't install packages like mqtt, via VIPM. So, if i download mqtt directly as package, how to install it? Also, if i download some LV project from github, how to install it in LV ?
Message 9 of 18
(2,903 Views)
which labview mqtt package do you want to use?
I'd use a ready (opensource) MQTT Broker like Mosquitto and learn to set up a MQTT Client in LabView e.g. run the Broker in virtual box linux machine and the client in windows via an .vi
Then see if you can setup communication between the Broker and the client.
Message 10 of 18
(2,893 Views)
