Lawicel CANUSB and NI-CAN on the same CAN network?
Hi, I'm trying to write CAN frames from the Lawicel CANUSB adapter and read them back on a NI-CAN adapter. I have the 2 adapters tied together via a standard db9 CAN cable, but they don't talk to each other. If I plug 2 NI-CANs together they talk just fine reading and writing frame data. Would anyone know why the CANUSB and NI-CAN won't work togther on the same CAN bus. It should work since they both support the CAN 2.0 standard protocol. Can someone please explain why this doesn't work.
Thanks...
(2,830 Views)
(2,818 Views)
