LeCroy programming
I use the LT262 scope with GPIB interface for remote control.
According to my program the scope executes number of sweeps with summed
averaging.
My problem is that how I can programmatically get the moment when all
the sweeps are completed.
I don't see any pending commands, after the sweeps starting ,for use the
OPC or WAIT commands (as STOPAfter in the Tektronix).
Thanks in advance.
Alexander.
Message 1 of 10
(5,764 Views)
Not sure that this is a solution for LT262 scope, but for a similar reason for LC334 I've used a "INR?" command continuosly polling the waveform processing bits.
Hope this can help.
Message 2 of 10
(5,763 Views)
Thanks,Defuflo,
but I get response from INR? after every sweep, so I need to count them
to obtain that all the sweeps are finished.
Is it right ?
Thanks.
> Hope this can help.
Message 3 of 10
(5,763 Views)
I'm not sure that the syntax for ?INR command and corresponding response are the same for Lecroy LT262 and LC334 scopes, but in my case there was no any need to count sweep by software - the waveform processin bit change state only after processing ALL requested sweeps (summarised and so on). So I continuosly poll those bits waiting for them to change state and only after I read waveforms.
Message 4 of 10
(5,761 Views)
Here is a part of code I've used for a particular application. Hope you can adapt it for your needs.
Message 5 of 10
(5,761 Views)
I use an LT342 and also poll INR? to check for sweep completion. However, I first read INR? to clear it before sending the *TRG command and use bit 0 of the response to determine completion of the sweeps.
Message 6 of 10
(5,761 Views)
Thanks!
Alexander wrote:
> Hi,
> averaging.
> Thanks in advance.
> Alexander.
Message 7 of 10
(5,761 Views)
essai
Message 8 of 10
(5,573 Views)
Hi ,
Anyone knows what is the command to set in Channel 1 Vertical setup, Pre-Processing Averaging 16 sweeps?
Message 9 of 10
(3,031 Views)
Hi Selvakumari,
Are you using the very same device as Alexander 20 years ago?
Anyway the answer should be: read the programming manual of your device to learn about the supported commands!
Message 10 of 10
(3,024 Views)
