Learn Multiple Geometric Patterns
Hi all,
I am using LabView and Vision to detect image from a USB camera but now i want to recognize template images in a retrieved image from the USB camera. I constantly get the error
Error -1074395628 occurred at IMAQ Learn Multiple Geometric Patterns
Possible reason(s):
IMAQ Vision: Invalid geometric matching template image.
Now i don't have a clue what the problem is, i even tried to do it with template editor but it also doesn't work. Templates are added as well as the code i'm using.
Message 1 of 10
(6,414 Views)
Is it possible to post the code you're currently using in .VI-format?
Did you create the code from scratch or did you start from a template?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 10
(6,345 Views)
Hi Thierry,
Sorry, i tried another solution since this one clearly was not working but it would be great if i could get it to work. So if you are willing to help me that would be great. I created the code (if you call it that way) from scratch but used the example found in vision. I couldn't get it to work though.
Thank you for your time.
Kind Regards,
Bob Rots
Message 3 of 10
(6,338 Views)
Sorry i don't know how to edit my previous post but i also get the error that its not a correct template image.
Possible reason(s):
So if you can help me that would be nice.
Kind Regards,
Bob
Message 4 of 10
(6,331 Views)
Hello Bob,
Can you upload the LabVIEW VI's/code that produced this error?
If you are not able to upload the .vi file, then please arcive it in a rar or a zip-file and use it as attachment.
To be able to help you troubleshoot the problems/errors you're getting, we do need the code/VI's you're using.
Kind Regards,
Message 5 of 10
(6,319 Views)
Here is my VI it now gives no error but it also doesn't work so i could use some help with this.
Message 6 of 10
(6,295 Views)
Hello SSJVegetto,
is this linked to the parallel post http://forums.ni.com/t5/LabVIEW/image-improvement-for-circle-detection/td-p/2236998
If yes, then we should limit ourselves to one thread, because it will become confusing otherwise.
Kind Regards,
Message 7 of 10
(6,260 Views)
ThiCop,
Yes it is linked. I was searching for a different solution to use but then i got stuck on that one as well.
Kind Regards,
Bob Rots
Message 8 of 10
(6,257 Views)
Then we'll first focus on the other post, ok?
Kind Regards,
Message 9 of 10
(6,243 Views)
Respected Sir,
                      My task is to recognize hexagonal shape (says bolts) which I place in front of my camera (Basler aca 2000-50gc) .I have to - "Train the Template during Live execution" and I am using  LabView 2012 and OS - Windows XP.
I am stuck  in -
1.Creating template path and how to use it in live acquisition of camera and then use it in geometric matching .
2.If I have 3 bolts of hexagonal shape then I have to make 3 template or just a single one.?
3.I am not allowed to use vision assistant .
4.Getting error 1074395628 in Learn geometric pattern vi.
                    I just tried to make a rough vi related to my task. Please go through the attached vi and respected template image and suggest me changes.
Waiting for your reply.
Regards
Shreya Joshi
Message 10 of 10
(5,868 Views)
