Least square linear-phase FIR filter
I need to geta second order derivative of an array based on 2 stage filtering with a least square linear phase FIR "differentiator " filter. Previously this was done using the matlab routine firls using the "differentiator" tag. Any ideas how this can be done in LabView?
Thanks in advance.
(2,869 Views)
I don't believe that LabVIEW has any differentiation functions that use this algorithm. The only derivative function is located in the analyze, signal processing, time domain. You would probably have to build your own.
(2,869 Views)
